I had my 1960 413 bored to 426 cubes ( I went custom forged but there are pistons available off the shelf for 426 bores), took it no problem and still had walls right around .200 thick on the thrust sides when done.
Scott,
You found 426 pistons with correct pin placement off the shelf that weren't 1000g cast rocks? EGGE has some but for the price..... Pass! I know Gbob had semi custom Ross build but still not cheap (383's with the pin moved.)
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
