I beg to differ on the torque output of the 413. The 440 and 413 are fairly close, and you have to remember that the 413 was "pushing" more steel and iron than the 440 back then. The 440 was made because they needed a more tractable, larger mill than the 413. Which in turn lowered the torque rpm from 3400-3600 (413) to 3000-3400 (440). With the exception of the Long-Ram Inducted 413 which made it's torque at 2700-3000 (approx. 490-500 ft lbs worth). I would gladly take a good core 413 any day.
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
