I made a production run of brackets for the Jesel stuff that solved the water pump clerance issue. I changed the distributor bracket so it mounted to the motor plate and then lengthened it a bit to clear the new reverse flow Meziere pump. I also added an adjustable TDC pointer to the crank trigger mount. Shoot me a PM and I'll get you a set of parts to look at if you're interested.
