Charlie, Bench racing is fun and you certainly enjoy it. Whatever the deal is between you and Jeff is your business and maybe you guys should keep it that way. Just my opinion.. If you disagree that's fine too, I'll respect that. How is the new stick car coming? I also have a technical question. Is there a formula you use to determine what transmission first gear ratio and ring and pinion ratio to use to maximize launch but minimize wheel spin? Thanks. Frank
frank that car in your profile is sweet, what class do you run in D1, i am building a 64 dodge for d1 stock.
