Originally Posted by TJP
Originally Posted by SomeCarGuy
Originally Posted by Sinitro
The Z-bar has small nylon bushings @ each end which can fall out if the Z-bar torques too much.
Suggest making sure the motor mounts don't have excessive end-play, and install a torque strap.
Just my $0.02... wink
iagree Any stick car should have a torque strap(we’ll probably most autos too) because once you feel how much easier they shift you’ll wonder why it wasn’t on the option sheet back in the day.
I also agree and every stick car I've owned had had one at the front and back of the motor. The back of the motor came about as we were losing transmission mounts after trips to the strip back in the day. We were on slicks with the suspensions set up so that may have been a factor wink
You don’t need a torq strap if you use solid engine mounts. Ride quality on the street will suffer a bit though. I currently run Mighty mounts with an adjustable torq strap and OE tranny mount. I tighten the strap when I race.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
