Clutch and trans are installed, Z bar still not straight across or level. The motor mount studs on the L and bolt on the R are all the way down on both sides. I have discovered the motor is not sitting level (leaning to the L (drivers side). The mounts and K frame appear correct.
If I raise the L side and level the motor it helps a lot with the Z bar leveling out but I am puzzled as to why it's sitting so low on both sides and how to raise the L side other than shimming it up. Normally one can "rock" the motor to level it on the mounts but in this case they are both at the bottom so the rocking idea's not going to work. Maybe it's a BB dart thing ? has anyone run into this before?
I can
1. Shim the motor till it's level which appears to be the root cause.
2. Move one of the Z bar ball studs, but I really prefer to find a correct the root cause
A couple of pic's of the K frame and Mounts that are in the car. Note the R mount has limited adjustment with one long bolt while the L has a lot with the slotted holes in the k frame that the studs go through
Any suggestions/ comments/ experiences?
Thanks beer
