Originally Posted by Sniper
Well, the Mopar pins are at .500" too so your screwed which ever way you go.
Correct except for Robb Robb mc, LINKY and Brewers pins which are sized correctly.
My error was twofold,
1. I did not think about the BH side of the dowel which also has to be reduced. That error pushed the offset portion into the block enough to seize it. but fortunately only on the lower accessible pin. The never seize may have helped wink
2. Again not thinking spank things through I installed the pins with the offset 180 degrees out of where they should have been. spank again.
I am happy to say the new pins are in and the BH is +/- .0035 which is within spec. Amazing how easy things can be when you think things through eyes
Will try for the clutch etc tomorrow beer
Opera Snapshot_2023-08-26_204700_www.brewersperformance.com.pngOpera Snapshot_2023-08-26_204541_www.robbmcperformance.com.png
