Re: New clutch, SEVERE Chatter from a stop NOW WITH PIC's
[Re: Rhinodart]
#3167972
08/14/23 10:06 PM
08/14/23 10:06 PM
Posts: 15,477 Omaha Ne
TJP
Omaha Ne
Holy crap! Some people should NOT be allowed to work on big block A-body's! I didn't read the whole thing but was the car complete and running before the clutch change? It is all straight forward with factory parts, which are all known and available except the bell housing that needs to be sourced, which is the 372 bell but also the 370 bell works just missing the hole for the spring which I didn't see in any of your pictures. I would NEVER use a diaphram clutch, no reason for it except less effort, but you can use a hydraulic throwout bearing if you have a weak knee. A mirror finish flywheel? Are they stoned or stupid? And not turning a used flywheel is also insane. I wish I was close by I could then tell why the bellcrank is at an angle, couldn't tell with the pictures. I do have pictures of my factory set-up, but it will take a bit to find them. In the picture of the parts I see a cut-up factory big block A-body bell crank and a small block bell crank. The ball stud bracket is a factory A-body piece also. Thank you responding, And yes it was I am thinking the angled Z bar is likely due to the Repro BH mount. But I have not checked the BH numbers yet but will tomorrow I have found the Z bar from southwest performance, 1 style of BH stud mount also from SW (First pic), and another from Hoffmans winners circle (2nd pic). I'm thinking the SWP Z bar is likely what is in the car. I likely have 2 different BH brackets but have to confirm. They both have weldments But I'm not sure if they are on both sides. The one in the car does. Why things are cockeyed I don't know and won't until I start taking things apart. I do wish the stock Z bar wasn't butchered and the stock BH bracket was in the pile but BUBBA must've needed them for his race car. 🔥🔥 My main concern is the Z bar arm length from the center of the tube to the center of the pin on the upper arms. If any one has that measurement I could use it to verify the repro z bar is correct or rework the stock on that is missing it's upper one. The rest I believe I can work around. Thanks to all and I Will keep reporting, Again any input is welcome
Entire Thread
RESOLVED!! PLEASE READ: New clutch, SEVERE Chatter from a
TJP
08/13/23 02:56 AM
PhillyRag
08/13/23 03:52 AM
fastmark
08/13/23 09:47 AM
Droop69
08/13/23 10:13 AM
therocks
08/13/23 01:20 PM
B1MAXX
08/13/23 02:05 PM
topside
08/13/23 02:54 PM
cudaman1969
08/13/23 03:16 PM
CKessel
08/13/23 03:36 PM
Sniper
08/13/23 04:25 PM
CKessel
08/13/23 05:00 PM
Sniper
08/13/23 05:16 PM
T2R9
08/13/23 07:59 PM
TJP
08/13/23 07:59 PM
stumpy
08/13/23 08:59 PM
Sniper
08/13/23 09:07 PM
TJP
08/13/23 11:57 PM
TJP
08/13/23 11:49 PM
Cab_Burge
08/14/23 04:00 PM
JohnRR
08/14/23 05:38 PM
TJP
08/14/23 06:22 PM
topside
08/14/23 07:01 PM
JohnRR
08/14/23 08:10 PM
Sinitro
08/14/23 10:16 PM
cudaman1969
08/14/23 10:37 PM
Cab_Burge
08/15/23 06:30 AM
moparx
08/15/23 05:01 PM
TJP
08/16/23 03:38 AM
PhillyRag
08/16/23 04:47 AM
TJP
08/16/23 06:46 PM
cudaman1969
08/17/23 12:03 AM
TJP
08/17/23 02:16 AM
SomeCarGuy
08/17/23 03:48 AM
PhillyRag
08/17/23 04:03 AM
ThermoQuad
08/17/23 09:27 AM
6PakBee
08/17/23 01:30 PM
68LAR
08/17/23 01:42 PM
Rhinodart
08/16/23 05:02 AM
B1MAXX
08/16/23 11:17 AM
therocks
08/16/23 12:33 PM
TJP
08/14/23 10:59 PM
JohnRR
08/17/23 04:19 PM
SomeCarGuy
08/17/23 04:41 PM
JohnRR
08/17/23 04:49 PM
TJP
08/18/23 01:52 AM
HotRodDave
08/18/23 02:13 AM
6PakBee
08/18/23 02:28 AM
cudaman1969
08/18/23 04:13 PM
TJP
08/18/23 06:11 PM
Sniper
08/18/23 06:46 PM
70sixpkrt
08/18/23 07:38 PM
TJP
08/18/23 08:06 PM
PhillyRag
08/19/23 01:21 AM
TJP
08/19/23 02:07 AM
ruderunner
08/19/23 10:59 AM
Re: New clutch, SEVERE Chatter from a stop. SOME UPDATES
TJP
08/22/23 02:24 AM
moparx
08/22/23 06:23 PM
TJP
08/23/23 02:10 AM
moparx
08/23/23 05:57 PM
TJP
08/25/23 01:39 AM
JohnRR
08/23/23 03:46 PM
TJP
08/25/23 01:45 AM
CKessel
08/25/23 02:06 PM
cudaman1969
08/25/23 03:12 PM
JohnRR
08/25/23 03:30 PM
TJP
08/25/23 03:56 PM
Sniper
08/26/23 03:04 PM
moparx
08/26/23 05:00 PM
TJP
08/26/23 05:57 PM
Sniper
08/26/23 07:05 PM
TJP
08/27/23 02:04 AM
6PakBee
08/27/23 04:29 AM
TJP
08/27/23 05:14 PM
6PakBee
08/28/23 01:57 PM
moparx
08/28/23 04:49 PM
TJP
08/28/23 05:40 PM
JohnRR
08/29/23 01:33 PM
TJP
08/29/23 04:33 PM
Sniper
08/30/23 01:17 AM
topside
08/30/23 01:56 AM
TJP
08/30/23 03:16 AM
B1MAXX
08/30/23 11:30 AM
JohnRR
08/30/23 03:50 PM
SomeCarGuy
08/30/23 05:27 PM
TJP
08/30/23 08:40 PM
Sniper
08/30/23 10:19 PM
TJP
08/31/23 12:26 AM
TJP
08/31/23 12:34 AM
A727Tflite
08/31/23 01:11 AM
JohnRR
08/31/23 04:00 PM
topside
08/31/23 04:57 PM
TJP
08/31/23 06:43 PM
JohnRR
08/31/23 07:39 PM
ruderunner
09/01/23 12:16 AM
Sinitro
09/01/23 01:46 AM
SomeCarGuy
09/01/23 04:10 AM
TJP
09/01/23 04:30 PM
68LAR
09/01/23 06:56 PM
Sinitro
09/01/23 10:01 PM
fourgearsavoy
09/02/23 01:35 AM
68LAR
09/02/23 01:51 AM
TJP
09/02/23 02:54 AM
TJP
09/03/23 02:35 AM
Rhinodart
09/03/23 08:32 PM
TJP
09/04/23 02:00 AM
moparx
09/04/23 05:38 PM
TJP
09/05/23 01:51 AM
6PakBee
09/05/23 01:31 PM
RESOLVED!!, SEVERE Clutch Chatter from a stop.
TJP
09/05/23 04:30 PM
Re: RESOLVED!!, SEVERE Clutch Chatter from a stop.
moparx
09/05/23 04:51 PM
ruderunner
09/05/23 10:05 PM
TJP
09/06/23 01:53 AM
Rhinodart
09/06/23 02:14 AM
CKessel
09/06/23 02:36 PM
TJP
09/06/23 08:19 PM
Sniper
09/06/23 09:34 PM
SomeCarGuy
09/07/23 02:11 AM
TJP
09/07/23 03:18 AM
TJP
09/19/23 09:02 PM
6PakBee
09/19/23 09:32 PM
340SIX
09/19/23 10:20 PM
TJP
09/20/23 02:40 AM
NITROUSN
09/19/23 10:22 PM
stumpy
09/20/23 12:26 AM
TJP
09/20/23 02:46 AM
TJP
09/20/23 03:00 AM
SomeCarGuy
09/20/23 04:59 AM
TJP
09/20/23 06:06 PM
moparx
09/20/23 08:03 PM
2boltmain
09/21/23 02:51 PM
TJP
09/21/23 06:57 PM
topside
09/21/23 10:57 PM
SomeCarGuy
09/22/23 03:59 AM
moparx
09/22/23 04:25 PM
ruderunner
09/06/23 11:44 PM
TJP
09/06/23 08:20 PM
JohnRR
09/06/23 04:36 PM
TJP
09/06/23 08:05 PM
TJP
09/01/23 02:09 AM
TJP
09/01/23 01:57 AM
JohnRR
08/31/23 03:55 PM
TJP
08/31/23 05:48 PM
dvw
08/31/23 06:13 PM
moparx
08/27/23 05:25 PM
TJP
08/28/23 01:43 AM
TJP
08/28/23 01:59 AM
SomeCarGuy
08/28/23 04:17 AM
TJP
08/26/23 05:54 PM
JohnRR
08/18/23 12:59 PM
Sniper
08/18/23 04:02 PM
Rhinodart
08/15/23 12:48 AM
TJP
08/15/23 02:06 AM
fourgearsavoy
08/13/23 09:11 PM
TJP
08/13/23 11:53 PM
JohnRR
08/14/23 01:55 PM
JohnRR
08/14/23 01:41 PM
HotRodDave
08/14/23 07:22 PM
