Forgot to add that Mike, so far with everything I have done,as far as checking what I'm gonna have to add or to delete,so far the torq WILL fit,looking like it is gonna have enough clearance(was really happy there),so far just the shifter bracket and modify the crossmember and find a drive shaft to cut down 3 1/2 inches down,the mods with the vacum switch and pressure switch is my thing,I don't want to do it twice,and switch the toggle switch,I want it to work on its own,been putting some descent parts away for the last year or so,5 pinion front steel 4 pinion low/reverse and 4 pinion overdrive 15 degree(alittle more strenght) and quiet,using the old style big block 2nd apply servo and acouple mods.....should be finished this weekend and some of the truck NEXT..weekend.
