So your using a non-lock converter 518 trans? Is that jw bell about $280? What about getting a 90-93 2x truck 518 cross member and d-shaft? Are you using the switchs from that site?
How are you building it as far as clutchs etc? Shift kit? Which rebuild kit?
Let's get some pics. When does the building start?
