Quote: One of my grandfather's favorite sayings was:
"Every job is easy if you have the right Tools"
to really do what you want to do you need EGT, wide band oxygen sensor at minimum and in the ideal case..... a set of eight spark plugs with fast reading pressure sensors embedded in them
Before using stock cast Magnum heads on a high compression and lean air-fuel engine set-up I would "temper" them in an non-oxidizing atmosphere oven at 520 degrees F for 24 hours, and then polish over the sharp edges in the combustion chamber.
BTW If any one wants to donate any of this equiptment I would love to have a chance to use it but I am broke. Also if someone wants to donate some part or another for me to try I will try them and give some real world feedback but remember I have no more money right now to spend on it. I have got some emails about stuff but I am not able to spend bottemless dollars on this. I will say it would not be this far with out some help from my friends, you guys, and my local mopar machine shop.
