Either way, the 'hard' part will be running the new throttle cable, and for us with automatics, the Throttle Pressure Cable (or kickdown cable )
Or is there something else I'm missing?
Nah, we're still planning hardware, I'm sure there will be more hurdles after that!
throttle and kickdown cables: Ford used a kickdown-type cable on their AOD transmissions, so a 5.0 TB from an OBD1 car should have provisions on it for 2 cables. 5.0 Explorers and 4.6 vehicles all had electronic transmissions, so no 2nd cable -- those TBs could still be made to work, perhaps?
Also, if you find a Lincoln Mark 7 with 5.0 HO, it will have the TB on the passenger side and the cable might be long enough to use, but you’ll have to figure out how to hook it to your pedal.
For cables, check out your nearest Dodge van and/or pickup. Some of them are pretty long, and the firewall-mounted footpedals probably fit in late-60s-up Mopars with little effort. The KD cables should be easy to use also. I also discovered that a ‘low-head’ allenhead screw (can’t remember the size, perhaps #6?) was a near-perfect item to emulate the cable pins used on a Maggie TB. The cables have a special square locking clip that goes into a bracket on the TB, either get that bracket to reuse or make the square hole with a drill bit and a sharp needle file (I’ve done it both ways). http://www.mcmaster.com/#socket-cap-screws/=6ufx2q
For reusing any OEM cable you’ll most likely have to modify something at one end or the other, so a universal cable or a Lokar might end up better on the time/money scale – each person has to decide for themselves.
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
