Anybody got any updates? Hoozie - did you find an engine yet?
I finally got a service manual to go with the ECM I have, now I need to go thru and see if the pinout info from fordfuelinjection.com is correct. I would've trusted that info for diagnosing a factory car, but not for re-tasking a Conti harness to a Mark ECU to a Mopar engine. 1 wrong wire could ruin everything, either in a puff of smoke... or silently.
In the next few weeks I'll start connecting the harness to some terminal blocks, then figure out what's next and what car/engine to try it on.
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
