i suppose wiring the fan directly would be possible, but it would take a 50 amp relay i suspect. so perhaps the ballast resistor on the trigger wire is the answer??? it seems like it would basically achieve the same thing, right. or am i missing something? the fan i have has that big metal box on it like the one you pictured.
