If you want to use one of the preset temperature ranges, you'll need to use either the autometer 2258 (1/8" NPT), or the GM sensor (3/8" NPT). I prefer the GM sensor since it has it's own ground back to the controller.
Otherwise, most any sensor should work, you'll just have to program it yourself with the turn on and high temperature points.
If you ever find yourself in a fair fight, your tactics suck.
