The connector for the 4 mm wire is 000-540-36-05. Is that the assembled cable, or just the pin that needs crimped to the wire? I'm seeing it listed at $5.25 each.
There is one available for a 6 mm wire. It is part number 000-540-37-05. $7.13. Must (hopefully ) be the finished cable too? You will have to verify that it fits in the plug with the fat wire. I believe it will since the standard wire has such thick insulation.
The weather seals are 000-545-79-80 (4 mm wire) and 001-545-05-80 (4.5 to 6.2 mm wire). Rubber ring. $2+ each
Hope that helps.
For what it's worth, when I need a VIN for a car I don't have I'll look at Ebay and other online car sales to find a car that has the option I need and grab its VIN.
If you ever find yourself in a fair fight, your tactics suck.
