Some of you need to get off your high and mighty soap boxes, like you are taking up for the "little" guys and others are looking down on them..........because you are full of it.
I am not sure that more than a couple people even got the POINT of the post and the rest just went into "oh my god, got to defend mode" not even knowing what it is they are even defending against. I tried to explain the point several times and most can't see the forest for the trees. NEVER, not ONE time, did I say SS springs were a bad thing, nor a bad option. I DID say they were not magic and you could accomplish the same thing yourself with some work. Some are so damn sensitive that they want to bend everything around you say, as you are Hating on Mopar, which again isn't true
