Quote: All the holes were drilled parallel to the centerline of the crank with the exception of the one not completely drilled.Had been drilled completely through it would have come out in the center main thrust journal.The hole was not parallel to the centerline of the crank as all the others.
I'd say that was an expensive f up in terms of fixing it. He did stop it before it came out tho. Saved Brandon some $$ anyway...lol I'm sure that much material there will have made a difference in the balance.
Well, art is art, isn't it? Still, on the other hand, water is water! And east is east and west is west and if you take cranberries and stew them like applesauce they taste much more like prunes than rhubarb does. Now, uh... Now you tell me what you know.
