Hi guys,Curt Jr.here While tinkering in the shop I think I have solved the great crank drill hole debate.All the holes were drilled parallel to the centerline of the crank with the exception of the one not completely drilled.Had been drilled completely through it would have come out in the center main thrust journal.The hole was not parallel to the centerline of the crank as all the others.See attached photos.
