Been 8.60s at 160s with one in a heavy ass streetcar. stock junkyard block, good internals, stock junkyard heads, stock truck manifolds, a blow through carb, at 3600lbs. And it’s going to go faster with EFI, and some better heads.
Light years ahead of any sb or bb. And way cheaper. You can buy 5.7s for <500 all day.
Like someone said above. Any idiot can go fast with a power adder. Pretty sure this is an NA application post.
ANY IDIOT CAN GO FAST WITH A POWER ADDER....LMFAO ! ! !
WE WILL SEE HOW THAT WORKS OUT FOR YOU I GUESS.....SHM ! LMFAO ! ! ! !
It’s 2019, take your purple cam and 906 heads and bury them in the backyard, take some Metamucil and take a nap.
How dare you insult the glorious beauty of the elusive purple shaft!
