VVT vs non VVT, that's about the only real difference. Cams are different and so are the front drives. Non VVT crank can be used in a VVT engine with a spacer, VVT crank can be machined to work in a non VVT block (need to turn some off of the front snout, can't remember the exact dimension but it's a simple lathe operation), hardly NASA level understanding
