yes Lights out means all power the car sputters to a stop all lights, fans, fuel pump etc. go out. I probly should replace my Shut off switch. I am also going to separate all my grounds as was mentioned above. Lights with Light, Fuel by its self, fan by its self and ignition by itself. I have all winter to figure this out. but already cant wait to drive it ion the spring
Top left couple wires at the firewall side of bulkhead is a fuseable link wire. I would bet that is your problem.
On a side note I ordered a piece of 1/4" copper flat stock for my heap.
Mopar to the bone!!!
