I have wired a few cars grounding everything to the frame. Yes, everything on the car worked. My newest car I wired it with floating grounds/busbar in the car. Then used ground cables to both heads. I used an alternator and ran a seperate battery cable to the alternator from the battery. Basically went wild with battery cable. Now thta its done I'm a believer. I think this car seems to crank better, charge better, start easier than any i have had in the past. Maybe its my imagination, but I really think it works I'm drinking the kool-aid on no chassis grounds. I know it adds work to ground this way instead of chassis but i think its worth it. I have done wiring work on offshore performance boats and you have to wire this way (no chassis).
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
