A ground is NOT a ground so to speak. Lot to be said for "clean" grounds and "noisy" grounds. Something like a starter, doesn't NEED a clean ground.......ANYTHING electronic DOES. You want to use the chassis as one big ground conductor, that's fine, many do, but it is NOT the best way to do it. I prefer to do it right and prevent any future issues. Seen too many problems too many times that drove guys crazy, that was fixed with a proper ground system.
I used to ground stuff like everybody else, to the chassis, until I learned better. Just because it is the way you have ALWAYS done something doesn't mean its the BEST way. You would like to think you do something long enough, that you find BETTER ways to do it........not the same old same oh.
Monte
I agreed with your post - in principal, but you gotta look at the bigger picture some times. For instance, is the added weight of having to run a ground cable from a rear mounted battery to the front of the car off set by the better conductivity of the cable over the frame? Doubt if you could measure the difference. The reason that it is still done the way it was done 30 years ago is because nothing "practically" better has come along. Change for the sake of change is not better. Who ever coined the phrase "change is good" must be in sales. Who ever invented "scotch-locks" should be shot. Minimum wiring, minimum ( and clean ) connections, still the best bet IMO.
Wire a few EFI cars.....chase your ass for weeks with EMI "noise" and get back to me on if its "worth" it
Monte
Ok
Fastest 300
