Hi Doug, I am chasing an ignition issue. I rewired the entire car this last summer. I chose to use a 20 circuit universal harness, way more circuits than I will ever need but I did it for a reason. Since the rewire I will be driving down the street and for no reason the car just stops(Lights Out no power) it has done this just sitting in the garage running. I will cycle the power switch the care restarts and everything is fine until it happens again. its really odd but I can only think its a ground or excess of grounds together or it is in my msd box.
