I thought I made it pretty clear.........I don't wire ANY grounds to the chassis, other than the lights. Also not exactly sure what "sensors" you are talking about, as they wire through a "sensor ground" output in the ECU anyway
Monte
Ok... yeah I forgot they go through the ECU... ok..
I should be fine
