Quote: I thought I made it pretty clear.........I don't wire ANY grounds to the chassis, other than the lights. Also not exactly sure what "sensors" you are talking about, as they wire through a "sensor ground" output in the ECU anyway
Monte
Ok... yeah I forgot they go through the ECU... ok.. I should be fine
That is why the ECU + and - go direct to the battery, so they are as isolated as possible from EVERYTHING, including the isolated ground. Im guessing that grounding the chassis solely amplifys EMI for everything. I think I get it.
I thought it was to maintain the memory... but I did run direct to the battery
