Quote: Just had a thought.............What if I ran a smaller gauge wire directly from my trunk mounted batts along the frame w/the fuel line for example BUT like factory cars, had it attached along the frame say every 2' or so............
Monte is talking about ISOLATED ground.. totally separate from the main ground... the ONLY place that they are common is at the battery itself... the battery acts as a filter and takes spikes and what not out of it
