Remember, one change at a time. I would test the .065's first and then the .063's if required. If you need to go richer after that, then open up the carb and change the IFR's. Good luck with the O2 purchase.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
