So I let the engine sit for about 3 1/2 hours to let cool back down completely, then I changed the .075 idle air bleeds to .070 idle air bleeds and I fired it up with the choke and fast idle on and it's not popping out the exhaust anymore. Is it possible that .005 change in the idle air bleed was just enough to tip it over the edge on the lean side?
