Matt... a little tip for ya... paint a white stripe down the whole length of each axle to measure the twist of them.. you will be surprised how much they twist... my Strange axles have a 1/2 a spline twist right at the spool edge and then twist down the length.. but the twist at the spool happened right away(in about a month or less) then it stayed that way... those are 35 spine axles
