Being that your running leaf springs and you need a back brace.. you can run a wider one all the way to the outer side of the spring pads then turn it in.. that way you run the spring bolts thru the back brace.. if you stop it at the spring pads the outer ends will bend.. this is my 9" but its for a ladder bar.. but you will get the idea at where the pads would be.. on mine you can see its angled all the way... yours wont be angled in as much till after the pad.. I've only done one this way.. most dont use leafs EDIT you will have to move the shocks which you should do anyways to mount then vertical
mr. P do you have any pictures of the internal bracing... if not I can go out and take some just in case someone's interested in reinforcing their own housing
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
