Only on a mopar site can we be called "too cheap" and "wastefull" of our money. Guys call us cheap for whining about $5000 for a useable block and at the same time people are shocked we buy them for that much.
BTW the advantage of the bigger BS block is you can run a bigger valve with more room from the bore, a hemi solves this problem.
Seems someone would come up with a race style Hemi head, ditch the "real hemi" chamber for a shallower one like the genIII with a couple quench pads so you don't need 500 pound pistons to get compression. Then you can beat em with a 4.8 BS while they are all trying to run a "wedge" that ain't a real wedge either. Look at the apache head, giant valve with big flow that still fits on a 3.91 bore for inspiration, no massive dome required. Scale it up and make it fit the 605" and let it eat. Too many mopar guys in the top classes trying to prove they can do it with a wedge. Does any one realize there would be NO comparisons of the Hemi and wedge if the hemi had 440" under it from the factory? That is the only real reason there was ever a comparison, the extra cubes are what gave it more TQ not the stupid wedge heads or magic 6 pack.
I've asked this a couple of times and gotten no real response (GenIII style chamber in a Gen II). Pistons would be a non issue, plenty of flat tops in Mopar BB sizes.
