If i can get a R3 block, 9.600" deck and 48* lifter bores for $2,500 I will buy it RIGHT NOW! As stated the old mopar thinking about "stock looking and stock valve train" has killed us. i will most likely be going to Gen III hemi for my next engine build. Also I'm still running a stock magnum block and pushing the 800hp-1000hp mark with it because good luck finding a R3 block out there....
