Quote:Quote:First ,What Are Your Engine Camshaft Specs ??? , As Far As Dirty Idle Not wanting to hihjack the OP but.... 440 engine, stock Chrysler cast intake, stock HP exh manifolds, 915 heads, 9.2:1 comp, stock valve train224 @ .050 duration & .504 lift Engle cam I am running 16º-18º initial timing. Pretty sure I can bump it up to at least 20º with no trouble. Im thinking its just the nature of the cam? Pulls 15" of vacuum at idle...
