http://www.tocmp.com/manuals/Carbs/Carter/Chrysler/1965-1979/pdf/Chrysler121-173.pdf
Heres the link to the Carter manuals- check them out. The '70-'71 AVS copies have the cfm specs. The primary and secondary throats are the same size on AVS' as are on Edelbrock 1400 and 1800? series, difference being the 1405 is rated 600cfm and the 1805 650cfm.
