RapidRobert I think you nailed it agsin! I connected my gauge and the Carter HP Mechanical Fuel pump is pumping out 9-10 PSI of fuel. Heading out now to see if I can find a regulator.
This should solve the rich problem and make me have the lean problem like everyone else!
