I recommend that you start a thread, get all of the Eddy 750 supporters to pull their money, buy you a good carb, and in exchange one of them can have yours to use every trick up their sleeve to compare it to a real Carter 750, an Eddy 650 or 800, or any Holley 750 and try to get the same power numbers or ET out of it, along with the same crusing A/F ratios, throttle response, etc.
Now I need to pin those needles, got to feel that heat Hear my motor screamin while I'm tearin up the street
