Thanks guys. Yes, I knew this would be a tough combination but I wanted to give it a shot since it looks pretty stock and I think/thought I was up to the challenge. We will see!
I have not checked the fuel pressure. I did use a HP, mechanical Carter Fuel Pump so that is a great idea to put a gauge on it.
RapidRobert, thank you for pointing out the WOT mixture. You are absolutely right in that I can't let the WOT get any leaner. At 14, I am already too high. I need to look at my chart again as you pointed out there may not be a good way to lean out the cruise and enrichen the WOT.
