as was said before build the biggest and best bottom end you can afford. you will eventually get the bug to upgrade and once the bottom end is solid you can do that easily. supercharger, done. nitrous, no problem, better heads, you betcha. we sell our girdle kits to help keep your bottom end together. since you going to at least line hone the mains, adding good caps now will save you some hassle later when you need them. our girdle kits are specially designed to keep everything in place and its the strongest out there and it works with all the stroker cranks.
girdle is a great idea
