every suspension system has faults---if you equate modern with superior you are mistaken---modern cars bottom line is $ if it saves a dollar or a pound of weight they do it--some cars have hardly any alignment adjustment left---if you keep them you have to put them on a frame machine to get it right----to the guys that want to show their finances off with a shiny new front clip more power to you---but when you bray about your superiority it brings to mind the mopar action article about putting viper brakes on a B body---they put on one side and went out to test the brakes--60 mph panic stop the car stops straight---their conclusion mopar made good brakes to begin with---if you want to spend the money on new shiny viper brakes--ok---just dont start bragging about how superior you are--to the guys moaning about wobbly wheels that drive them till they fall off--if you were any kind of mechanic you would replace the ball joints or the wheel bearings--or like most guys you buy the whole front end kit because you know these cars are 50 years old
