I got the pass. wheelhouse off, and here is a picture of the replacement. It fits pretty darn good from what I have found so far. I put the new pass wheel house on, it fits better than the drivers side. But I did a better job of removing the old one the second time around on the pass. side. I forgot to take a picture of the pass side before I hung the quarters. Here's what a outer wheel house looks like.
I did another fitup to check things out. I think I can make this work. All panels are in place. I started to scribe stuff that will need to be modified. The trunk extensions will need the most work, but it looks doable. I think I'm gonna weld the trunk pan and extensions in next.
