Quote: Hi, Can you post a picture of the cutter please. As i am in Australia and they may be called something different here than America. Is their any other name for these as i can look on e-bay aswell. Not trying to take over the thread but i will be doing the same method of panel replacement as Challenger125. Thanks, Kenny.
No problem at all,glad to answer any questions that I can. Yup those are the cutters, they work very nice and have held up. I'm still on my first one, and I used it dry because when I tried using cutting oil I could'nt see as well.
Good News! I got the floor out,and the inside of the rear frame rails are solid with very little rust inside. Still have the outer wheel wells to get off.
I drilled the wire hanger straps off the drivers side gutter that will be spot welded to the new pieces. I was too cheap to buy a new spare tire mount so I have to strip it from the old floor still. Gonna go get those outer wheel wells off now.
