Well I had to take a picture of the spindle before i put them on and they get covered by the rotor, they look so...clean
Since i cannot find anything as far as a complete 71 two piece proportioning valve, i was forced to salvage a 72, i hate the concept as they just dont look nearly as good. Since they mount differently on the inner fender and i wasnt going to drill the inner fender, i made a bracket so when the time comes i can switch it without having to fill the drilled hole. I took the bracket picture below the bolt (this one and another) and made a bracket. So i went from this...
