Hey guys took off work early to get 2 hours in tonight on the car. Greg came down and helped out too!
I addressed the issue of our rusted out speaker tray. Here i cut out the old speaker area...
I could actually save the one side, it does have two holes that need to be fixed but it much better than the other side. The left is the original the right is the new...
Tacked the ring and then welded it...
The complete ring welded in...
Then i did the rear defrost area...
Here she is welded in...
While i was doing that, greg was prepping the area for it to go and then started stripping the engine bay to fully see the rust in there...
