Okay guys we are getting closer to completion of metal work every day, instead of replacing the rear pan with one we dont have we decided to weld shut all the holes and patch the one needed area...
Then we took out the front suspension. We used the old man's just suspension torsion bar remover which worked out well after we spent 45 minutes trying to figure out why it would not budge. Turns out a stupid forgetful step of releasing the tension from the Lower control arms...
