Random question for you guys. I have a mild 440 in my '68 Fury with ported 906's, 0.590 cam, flat top pistons and a TM7 intake with a 4 hole 1" spacer and an 850 DP on it.
I'm looking to spray it to get it into the mid 11's. I eventually want to fuel inject it and use a plate kit as a dry nitrous shot only and let something like a Holley Sniper control the additional fuel. I understand a ~150-200 shot should be safe on the motor as long as I use window switches and a WOT switch to keep it from activating when I don't want it to. I also understand I'll have to pull ~10 degrees of timing to keep it from detonating.
My question is what plate/kit would everyone recommend for this if I'm starting from nothing, for use with a carb for now, and then if I convert to EFI, can the wet kit be run as a dry kit only with no fuel through the fuel spray bar as long as the FI system is supplying the additional fuel?
Thanks!
'18 Ford Raptor, random motorcycles, 1968 Plymouth Fury III - 11.37 @ 118
