i am thinking of running a 2 plate stacked 2 stage system. the 2nd plate would be a completely seperate system except for the fuel. i use a dedicated fuel supply mounted underhood with a holley blue pump. i would run the fuel for the 2nd kit off the other side of the regulator. am i asking for trouble?
the first hit would be a 150 hp hit off the line with a 250 hp hit in 2nd gear.
motor is built for nitrous with forged pistons and proper ring gap.
I was told not to do that by guys that know a lot more about nitrous than me. You need a separate regulator for the 2nd kit. Not only to set the pressure for just the 2nd kit, but b/c of a supply issue at the regulator.
