This is my 1st time dealing with a pro mag. If I remember right you run big stuff 3. Do you run it from the standard location or is it cam driven . What box do you use with it? What do you do to pull timing with the pro mag? Is it easily programmable.
I will be ordering parts later this summer and hope to have the hemi running next summer. Depends how this season goes with the wedge.
