Well, I have been hard at it on mine! I now have power steering, power brakes, and tilt column!!! Also I installed a electric cooling fan as a helper unit for those warm summer days. It is like driving a different truck, well worth the effort!! I had all kinds of trouble with pulley alignment on the steering pump, but got it all worked out. Mind you Fri evening it had manual steering, non- power brakes and non tilt column. The next step is a super six intake and carb, 2 1/4 outlet exaust manifold. It already has a 2 1/4 system, but the current manifold has a 2 in outlet. The o'l six needs all the help it can get!!
84 D150 440/727 79 /6 swb D150 1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
